I recently reinstalled "all-nokia-data-etc" and "all-memorycard-etc" after having had to format the whole device because of serious Word and notes problems. Everything seems to be working properly, except that now, when I enter a new task, it does not go to the date I enter in the appropriate line (and indicates that alarm is in the past). I have to go to the calendar, go to the date of the new task and then enter the task itself. Is that normal with the updated versions ?
Any idea / reply / solutions ?
Task after reinstallation
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2001-11-28 1555, Charlie wrote
...when I enter a new task, it does not go to the date I enter in the appropriate line (and indicates that alarm is in the past).
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Same thing but it goes to that day what i enter after "alarm is in the past" warning.
Task is ok, but alarm not (3.62)
Maeby fixed in new fw..
