Internet Connection Over Bluetooth?
2 replies · 2,072 views · Started 25 August 2004
Is it possible to enter internet with my N7610 without using GPRS , but with bluetooth connection over my desktop computer's DSL?
i'm not sure, but if you have a bluetooth enabled pc try this.
Open your network connections, find the connection that you use to connect to the internet, right click, properties, go to sharing, choose BLUETOOTH.
Now pair your phone with the pc.
You'll get a window with all of the possible things to do once paired.
If there is an option to "Allow Access to Network" then yes, if not, then no.
