usb cable
6 replies · 2,008 views · Started 25 August 2004
hey is there anyone using that cable with windows 98 ?i couldnt install it can u help me with installi,ng
kivanc12 wrote:hey is there anyone using that cable with windows 98 ?i couldnt install it can u help me with installi,ng
You can only install it with XP Service pack 1
Unregistered1 wrote:You can only install it with XP Service pack 1
I dont think so .. One can run it on 98 too.
It does clearly state on the Pc Suite that the software only works with XP SP1.
Why Nokia cant rediesign the software for all platforms is abit of a mystery but having worked in the business for a while stranger things have happened.
Dave
Have been reading comments about the usb cable and getting it to work on windows 98, some people say that it is compatable others say only work on XP SP1. If any one has successfully installed in on windows 98 second edition, please tell me how!!! I am pulling my hair out!!!
Don't waste your time trying. It will only work on Windows 2000 or Windows XP (there are only drivers for those OS versions).
