3650 installing probz
3 replies · 1,484 views · Started 25 August 2004
This thread included a poll: what phone is better
i recently bought a 3650, i try to drag and drop the files on the mmc card (.sis) asnd the app manager shows up a message with no data, i even formatted the mmc and then dragged and droped the files on to the card and still luck, any one HELP PLLLLLLLLLLLZZZZZZZZZZZZZZZZ : :redface: (
You need to execute the sis installer from the MMC directly. For the application to appear in App Manager then it needs to be saved to the C:\Nokia\Installs directory.
To install files from your MMC, you'll need to install something like FExplorer first. You'll have to use either Bluetooth or Infrared to do so. Once its installed, use the program to browse to the directory where you saved the sis installer on the MMC, and select Open (the MMC is represented by the drive letter E:\).
Once you've installed it, be sure to delete the sis file from the MMC if you want to conserve memory.
If using bluetooth, Right click the sis file on your computer, click on "send to bluetooth" it will send as message, when you open message it will install.
