A question about ringtones on the Sendo X
3 replies · 2,186 views · Started 25 August 2004
Hi all,
I've just registered on this forum. I am very interested in the Sendo X phone as many others. How many ringtones does it have? Are there any monophonic ringtones or are their all polyphonic? Just curious!
Best regards and thanks,
Christian
It has stereo speakers. It can play whole songs! Or you could use it for monophonic ringtones if you wanted. It comes with some wierd ones, but you can add your own in virtually any format (except .mp3 or .ogg).
Basically it will do what you want it to do because it can do any ringtone.
I have just tried successfully compressing some WAV files using dBpowerAMP Music Converter into IMA ADPCM which has compressed 5MB files to 1MB and then copied them to my Sendo X file location C:\Nokia\Sounds\Digital and then set it as my ringtone...now i have cool ringtones on my phone now!
You can get the app from http://www.dbpoweramp.com/
