I have had 3 nokia 3650's in the past 6 months and a 4th is on the way as of 8/30/04. All have the same turn off problem. It's not the battery.
It happens without any notice - anytime, anywhere: shelf, on/off the charager, night/day - NEVER while on a conversation. No reoccuring pattern toatally random. I have seen same issue posted around the internet.
Phone is totally stock: I have not added any aftermarket software. I think I have latest firmware. My location is California, USA and provider is T-Mobile. I am surprised that this is little know and talked about even on this forum. I take very good care of each phone, the battery cover is on tight so all the know brainer's are ruled out. Also, after starting up from a turn off the phone will often turnon fail to start an hang in a zombie mode.
Nokia and tmobile all deny an knowledge of this being a "known" problem. AT&T and other providers stopped carrying Nokia 3650.
This is definitely my last nokia phone ever unless nokia acknowledges the problem. I am still under the 1 yr warranty but all I get is someone elses phone with the same exact problem. I believe they should be class-action suited.
Any help or info would be appreciated. I like the phone otherwise and fully use the bluetooth.
My review ranks #1 in Google: Key words: "nokia 3650" turns itself off
http://www.epinions.com/content_134459395716
Search for key word "turns itself off"
http://www.mobile-phones-uk.org.uk/reviews/nokia-3650.htm
pcofranc wrote:I have had 3 nokia 3650's in the past 6 months and a 4th is on the way as of 8/30/04. All have the same turn off problem. It's not the battery.It happens without any notice - anytime, anywhere: shelf, on/off the charager, night/day - NEVER while on a conversation. No reoccuring pattern toatally random. I have seen same issue posted around the internet.
I have the exact same problem. Piece of shit Nokia, and piece of shit Nokia 3650 phone!!
Have you found any way of getting it out of this "zombie"-mode? It just happened to me first time now, and I can't get it out of "zombie"-mode; with the result that I'm stuck with a completely useless phone.
Should have smelled this coming when I first laid my eyes on the round keyboard... 😊
I had the same problem, when many apps are installed on the phone stability goes away.
devinfriday wrote:I had the same problem, when many apps are installed on the phone stability goes away.
same problem with my phone..any info why this happen?
i just added a few notes paper under back housing and problems gone...
i have also same nokia 3650 and i always try to exploit the phone. i think i installed more than 20 softwares which are legal or cracked. but so far no problem like gets OFF. i like this phone very much.
regards,
baiju.
no its not cos of applications, i formated my phone and mmc, still my phone booted. its a universal problem of 3650. even 3660 boots the same way. 🙄
