New Extended Profiles beta
9 replies · 2,858 views · Started 30 September 2002
Now is available new Extended Profiles beta
http://www.psiloc.com/nokia/eng/eprofiles7650/index.html
I think I'll wait for the version that reads my mind ... or at least integrates with Calendar 😉
Extended Profiles now extends profile switching feature, one can select for every profile diferent background image, colour palette, screen saver (Screen Saver application is fully supported), idle softkeys etc.
This feature works with conjuction with profile schedules and with normal profile switching (via power button).
PsiNT
one small improvement i could think of is that if you added the feature to enable users who do not wish to purchase world clock the feature the ability to select there working days ! just for ease of use this is !
I know that you may want to get ppl to buy the 2 for the extra feature and if this is the case I reckon you should add the * WEEKDAYS option to the program for all of those normal monday -friday 9-5 ppl out there !
just a thought ! ( even if some of us do finish early on fridays 😉 )
PS Excellent work so far ! 😊
well sound slike the developers listened to the suggestions people have been making.
Now if they would only not charge for it, I would use it 😊
To Mikeprice53:
1. Working days is global setting, fully supported by OS (but by default there is no chance to change default one). Because this is global setting (e.g. Calendar also uses this setting) can be changed only by World Clock (it's "regional settings" part).
BTW World Clock application is only one that filles that (and other) holes.
2. You can use trial version of World Clock to set working days.
3. Extended Profiles 1.19(3) beta is available to download, now one can set occurence to 'Selected days' also.
excellent cheers !
just clearing that up for me is gr8 but i was merely suggesting it as to install world clock takes up more room on the small ammount of memory you already get....
look forward to the next few releases !
Think i will end up getting Screen Saver soon tho ! 😊
