hi...can anyone help me please? I have just installed the original stuff that was on my 9210i when I bought it..I don't want DATA MOVER and I'd just like to know if there's a way that I can REMOVE it.Apparently I can click on REMOVE on the right hand side of the fone but REMOVE is nowhere to be seen.Please help..thanks a lot!
Help
It isn't isntalled seperatly so you can't uninstall it. You could trace all the files and delete it.
Data mover is in my lsit of installed software and I can remove. I don't see any problem for removing it, as it should not effect other application. As I have a 9210, maybe Nokia has changed something in the 9210i. But basically you either need this application once or not at all. If the remove button doesn't work, delete all the files under \system\apps\mover. You might wanna check if there is a mover.sis file under \system\install. If there isn't that might explain why you cannot remove it automatically.
hey guest..
i've a 9210i .. and the DATA MOVER is installed already.. it doesn't make any problem, and it won't fill ur memory, what if u needed it some day? 😉
PS! u can register by clicking on Register, on the top of the page 😃
