How to connect N3660 and N7650 using Bluetooth Serial Port in WinXP SP2 using a winxp sp2 driver of the bluetooth? i have an MSI btoes bluetoohth,can anyone help me??? i'm having a hardtime to connect my phones to synchronize in Nokia Data Suite, when i'm trying to add in the PAN, i can't any single mobile phone device.
And my new Nokia 7610, i know that Nokia 7610 does not have a Bluetooth Serial Port, but how can i connect to synchronize??? i'm now using an usb cable to get synchronize but not in bluetooth. also can't add to PAN.
or i must wait for the new driver of BToes??? i'm using the first driver of WinXP Service Pack 2.
Please help, thank you...
mjsee wrote:can anyone help?
Well, not really :tongue:
Actually I had a hard time trying to get NokiaSuite running with an IVT bluetooth dongle and the included BlueSoleil software.
Somwhere on the nokia site it says NokiaSuite is compatible with WidComm Software. The BlueToe comes with Widcomm, so I ordered one of those Bluetoes too 😊
Well perhaps you could go to the MSI page
http://www.msi.com.tw/program/support/driver/dvr/spt_dvr_list.php?part=8&kind=23&CHIP=23&ID=8
and check the bottom of the page for the driver pack. Try installing widcomm first.
erm, and tell me if it worked or if I have to cancel that order 😊
Good luck,
Barely.
The PC Suite for those older phones was done before SP2 and its Bluetooth drivers, and before IVT BlueSoleil. So, you're not likely to get things to works, except with the Bluetooth software supported by the old PC Suite versions.
The latest PC Suite supports XP2 drivers and also BlueSoleil, but it doesn't support the old phones.
so that's why i havent been able to get my 6230 to sync using bluetooth in the last couple of months... since, oh, probably about when i installed sp2... cool.
