One day, out of the clear Bule Skies, my phone sitting quietly on the desk, rebooted by itself. This is the last day I would see it working correctly.
After it rebooted, it started up and then returned the following error while booting:
App. closed:
MsvServer
Below it, is an "ok" Button. I pressed it - the phone rebooted again -- and then I would get this error again. There is no other way I know to get to the phone.
I tried the basics: turning it on and off manually, removing and replacing the battery, charging -- nothing works. I'm very pissed -- can anyone help?
yeah dear friend i had the same prob. too but dont worry there is a simple solution..... FORMAT!!!!!!!!
and the method is
turn off ur phone
press the green dial key, the *key and the digit 3 key together and turn ur phone on while the keys are pressed and wait till the phone's screen displays formatting... andthe data on ur phone wud be erased but not on mmc.
enjoy.........
Hello!
Afterr i've tried to set my N-gage back to factorysetting my phone says also MSVserver error, and reboots again and again....
Don't know what to do about it now....😞
Does anybody knows how to format an Ngage plz?
HELP MEEEEE!!!
[email][email protected][/email]
*#7370# for reformat. If you need more instructions, then the search function is your friend: http://www.allaboutsymbian.com/forum/search.php
there's no need to format ,
i believe that you have screen saver installed inside your phone ,
uninstall it and this will solve your problem .
enjoy
migz123 wrote:One day, out of the clear Bule Skies, my phone sitting quietly on the desk, rebooted by itself. This is the last day I would see it working correctly.After it rebooted, it started up and then returned the following error while booting:
App. closed:
MsvServer
OK - if he can not get the phone to come on how does he un-install anything??
That error message is due to the screen saver installed , the phone can be switch on i believe.
uninstall the screen saver will help as this happen to lots of people and also me .
try it
I'm facing the similar problem on my N-gage Qd, is ther a way i recover it? I tried all the solution given in this forum...unfortunately it didnt yield ny result.
pls advise.
-karthik
App. closed:
MsvServer
Have you tried to use 'safe mode boot' ? Try to boot up your phone with pressing only the key button.
I had similar problem with two N-Gages, and then i returned both N-Gages to store, and bought 3660. Currently i am using 6600 and it works like dream! 😊
If the 'safe mode boot' won't work, you'll have to take your phone to Nokia service.
Right Way
sibtain wrote:yeah dear friend i had the same prob. too but dont worry there is a simple solution..... FORMAT!!!!!!!!
and the method is
turn off ur phone
press the green dial key, the *key and the digit 3 key together and turn ur phone on while the keys are pressed and wait till the phone's screen displays formatting... andthe data on ur phone wud be erased but not on mmc.enjoy.........
Rizwan But After formating by Keys or code you will have to swich off the phone af it ask foe time.
do not carry on Swich off the phone and wait for 15 minutes and than you can proceed and i hope you will get better result.
