GPRS Modem
3 replies · 3,494 views · Started 29 August 2004
Yes!
I've been using the belkin bluetooth adaptor. theres a couple of little tricks you need though.
The main one is setting up the connection itself. to do this click on the actual modem itself in control panel, it will be call bluetooth modem i think.
In the advanced bit there's a field called extra initialisation string. you need to enter
at+cgdcont=1"IP","APN"
where APN= the access point your trying to access. For example this could be web.omnitel.it.
Dont be tempted to insert an IP address where is says IP!!! Its meant to say that!
open you Dial up networking connection to the phone, and insert the username and password for the access point, and enter the telephone number *99#
then Dial!!!
Good luck, let me know how it goes!
