Hello everybody,
I would like to ask you a simple question. As far as it is possible to allot a ringtone to a contact. Is there any software that allow to do this with the sms ?
I receive email notification by sms from my provider and i would like the phone to ring in a different way for this kind of sms.
I did a search but did not find any answer...
Thank you for your help.
Strider
There is no built-in capability in the phone to do so. I don't know if there are any applications that allow that, but look around here:
http://my-symbian.com/7650/applications/index.php
Thank you,
I have noticed that it was not possible with the original symbian OS 😉
I am going to explore the link you give to me. I hope to find something, i will tell you!
I have not find what i am searching...
Maybe Mumsms will help me but I also want the software to work on N-Gage.
Thank you for your help. Does anyone else have an idea ?
I go on searching and will tell you!
MumSMS has nothing to do with that.. Its purpose is another...
Take a look in this thread...
http://www.allaboutsymbian.com/forum//forum/thread/21491/
It will not solve your problem, but will add you knowledge in the topic..
Thank you,
I said that that Mumsms "can help me" but not "solve the problem"
I understand the purpose of this software and i also use it even on my ngage!
it seems like the API related to (sms) ringtone or calls is a little different in Symbian7 when comparing to Symbian6 ..
anyway, until now I haven't seen an app that deals ok with sms ringtone as you may have read on the other thread I posted the link.. :frown:
