7650 Battery
6 replies · 2,108 views · Started 30 September 2002
When i charge my 7650 with my 8310 charger i think it will give me more talk time, but i cant confirm if it is real.
Maybe because the output amp.. (just a though)
8310 charger: type ACP-7E output 355mA (slower charge time)
7650 charger: type ACP-12E output 800mA (faster charge time)
the slower charge increase talk time ?!? maybe..
if someone can confirm (or not) this.
I dont think the charger will do you any good.
Usually the battery time is governed by the batter capacity.. The standard battery is rated at 750maH .. Which is 750 milli ampere hours.. i.e. if the phone consumes 750 ma then the battery will last for 1 hour (😉)
So what you need is a higher capacity battery.. I think the 8310 has a 950maH that is supposed to work with the 7650.. I read somewhere that there are 1000+maH battery available from third parties.. Can someone confirm this ?
Yes 😃 There is really such Batt. In Singapore there is a third-party company doing 1000mah batt, but it's already been sold out. Hot cakes!!!!
I will be checking it out these few day after my work. I will keep you all posted. Hopefull can snap a shot for the batt if allow 😉
I use a tird-party battery thats 1100ma
I bought this from www.solware.co.uk, they have loads and its only �13.95!!! A good buy!!!
I use the phone for about 4hours of talktime a day and about 2hours of tinkering.....i.e. playing games, messing around with OP logos etc..... and the 1100ma battery lasts me two days!!!!
The only thing is that the 1100ma batter is about 2mm thicker than the original....but the battery case fits perfectly!!!!
have bought a bigger battery, too ... 750 mAh are quite lame 😉
there are several shops offering 1000 or even 1100 mAh akkus for the 8210, 8310 and 8810 ... they perfectly fit into the 7650's battery case and work and work and work ...
