Nokia 7610 Wap/GPRS Problems
2 replies · 1,829 views · Started 30 August 2004
I purchased a sim free Nokia 7610. I use my oragne pay as you go sim card, but i cant get wap/gprs to work. Orange send me the settings but it never works, shop have tried everything.. i am lookin for a genies to step foward and help...Please!
I have tried inputing manually but no luck does anyone have a reason for this??? :con?
EnglandPsycho wrote:I purchased a sim free Nokia 7610. I use my oragne pay as you go sim card, but i cant get wap/gprs to work. Orange send me the settings but it never works, shop have tried everything.. i am lookin for a genies to step foward and help...Please!
Make sure you get through to third line support. These bods really know their stuff. They sorted out a problem for me where I could get GPRS but not low speed dial-up. I then had to go back to 1st and then 2nd line support to get the correct combination of SIM updates.
There are some port settings which need to be manually done in 7610. I had a similar issue where Orange kept sending me the settings and i was saving them. But it did`t wwork... Then i had to manually type in some port settings which i don`t remember now...
