Hi guys!
I ve recently transferred a .sis file from the pc to the phone through infrared. I ve run the file and installed the program. After installing the prog, I tried to delete the .sis file but I get the warning Error Deleting File General: Already in use!
I ve tried to move the file to My Folders etc, but still the file wont be deleted
Any suggestions greatly apreciated
Thank you 😃
Try turning off ur 6600 and then on again. U should be able to delete after that.
[FONT=Comic Sans MS]I'm having the same problem, I installed a freebie program, ran it for a while, decided i didn't like it, so uninstalled it, but the sis file is still in my sms inbox, how do i get rid of it?? 😡 [/FONT]
1) get FExplorer
2)Findout where ur messasges r saved by going in2 messages > Options > Settings > Other > Memory in use
3a) If it says Phone Memory then open FExplorer
C: > System > Mail > Then search thru the folders until u find the message u want 2 delete and delete the folder it is in
3b) If it says something other than Phone Memory then open FExplorer
E: > System > Mail > Then search thru the folders until u find the message u want 2 delete and delete the folder it is in
4) Check if it worked
I followed all instructions and I was able to delete the messages from my inbox. The trick though is to properly look from the system\mail folders. Once you delete said file from the Fexplorer, then you can delete said files from your inbox.
Thanks for this very useful advice. Now I have reclamed my previous space...
littledude wrote:1) get FExplorer 2)Findout where ur messasges r saved by going in2 messages > Options > Settings > Other > Memory in use
