Maxinote for Series 60 is an alternative Notes / SMS program. It gives another way for you to eneter text into your phone either to send SMS messages or to make notes. The majority of the text entry is done using the phone's navigation key and as a result writing can be faster.
Author's Description:
Whether you're creating text messages or simply jotting down notes you can now input text using Maxinote's fast and friendly on-screen keypad.
The Maxinote design allows you to keep your focus predominantly on the screen while performing the majority of input actions using your mobile phone's navigation key. Visit www.mobystar.com for a complete description of Maxinote.
Alternatively, why not download the trial version immediately and take The Maxinote Test to see how Maxinote can make a difference to your usual texting activities.
Maxinote v1.0 Feature List
* Customisable words and characters
* Easy access to extended character symbols
* Customisable cursor/input actions (wrapping/re-centering)
* Customisable text display (plain/bold, close/normal, black/blue/green/red/grey)
* Editing operations (cut/copy/paste/undo)
* Searchable mobile contact list (by name or number)
* Send text message/saved note immediately or send to native text/email/MMS editor
* List and search for ''mobile only'' contact numbers in phonebook
* Send text or saved note to Bluetooth enabled device
* Send text or saved note to Infrared enabled device
* Save messages (notes) up to 2000 characters long
* Open, Move, Delete Notes
* Display note folder details (preview/size/date)
* Save secure (password-protected) notes
* Save/Load HotText cell groups (as set 1, 2, or 3)
* Enabled/Disable keypad (Maxinote or standard editing mode)
* Enabled/Disable fullscreen
* Enable/Disable backlight (always or timeout)
* Online help (Options->Info->Help)
* Display mobile internal memory/MMC details (Total Size/Free Space)
* Display mobile device IMEI (International Mobile Equipment Identity)
