Help
My Calander seems to have corupted... how the hell would that happen.
If i go into it all looks ok but if i try and open a day i get an 'app. Closed Calander'
I use my damn calander for everything so will be in major trouble if i can't get it working.
Your help please :con?
Sounds strange. Have you installed any apps that read/write the calendar & may have corrupted the file? Anything else you installed/used just before it happened?
A full format will restore the phone to the state it was in when it left the factory (all contacts, messages, settings, pictures, etc., will be gone, though).
Searching http://www.allaboutsymbian.com/forum/search.php should find you many topics describing how to reformat a 7610 (or 6600 as the procedure is the same).
