I'm looking for this since I have the 7650: Is there yet any software which allows to set the sounds (midi, wav, etc) as alarm? The peep of the original alarm doesnt wake me up ... 😊
Set sounds as alarm?
I haven't yet got the answer to this, but have you tried facing the top of the phone towards you, which is where the speaker is positioned? It may help a little! 😉
[quote="Freddie666"]I'm looking for this since I have the 7650: Is there yet any software which allows to set the sounds (midi, wav, etc) as alarm? The peep of the original alarm doesnt wake me up ... 😊[/quote]
I have the same problems: see in Z the clock.rng, but you cannot write a a Rom drive, so it seems impossible to manually change it. It should be programmed to do this.. out
