does anyone hav seleQ for 7610??
7610 sele Q
Try the shop: http://www.allaboutsymbian.com/shop/
If you want a free file manager instead, try FExplorer instead: http://www.gosymbian.com/
Sele Q is not fully compatible with Nokia 7610. Its Option but does not work and if we want it to be work then we have to select any file as "marked" and then it works.
Fx Exp would be more better in case of Nokia 7610.
the Fe explorer people should add the encrypting function to it. then it will be the best software ever! i mean the most useful one!
It is the one of the Best Freeware Software too.
uhh.. yes vicky we get it.. how many times will u post the link to that site? its like u've made that software! sheesh! anyway.. my hundreth post 😊) very happy!
😃, its such a good app it deserves to be mentioned several times 😉. Seriously, free software is quite lacking on S60. FEexplorer is definately the best of the small group that is avalible.
silkshadow wrote:😃, its such a good app it deserves to be mentioned several times 😉. Seriously, free software is quite lacking on S60. FEexplorer is definately the best of the small group that is avalible.
Its only 'so good' because of its uses,SeleQ is better.
Has anyone been on to them a about version that works on 7610?
I have psiloc efilemanager,he is much better then seleq and he works on 7610
The key word here is 'free' 😃. Efileman is good, much better than seleq. Next I am going ti give filman a try. Resco has said they are considering porting their explorer app to S60. I hope that happens.
