FS Caller - Memory Full
3 replies · 6,325 views · Started 01 September 2004
Hi All, after reading on some recomendations on Full Screen Caller, I went to Symbianware web site to purchase a copy. After installing into my handset using the PC Suite, when I try to attach a photo to a caller name, I had this message ... FS Caller memory full. Close some applications and try again. In actual fact, I only have this application activated "on" and the SmartProfile application activated "on". I do not have any other applications running back end. Can any body help and advise? Thanks.
I have it quite often, same error.
But at all times, despite I thought that there are no programs running, I always found later that I have to close Schedules, Contacts, RealPlayers etc. Note that you have to completely turn off these things by the proper procedures Exit, Exit, exit. It is no use turning them off by just hitting the Red Off key at the right upper corner of the phone.
I think it should be depending on the image size.
I have this problem with images higher than 600 - 630 kb, with other I don't have it.
I'm using version 3.0
Unreg FS Caller wrote:Hi All, after reading on some recomendations on Full Screen Caller, I went to Symbianware web site to purchase a copy. After installing into my handset using the PC Suite, when I try to attach a photo to a caller name, I had this message ... FS Caller memory full. Close some applications and try again. In actual fact, I only have this application activated "on" and the SmartProfile application activated "on". I do not have any other applications running back end. Can any body help and advise? Thanks.
Thank you CPWONGHKG and Magnificus. I shall try to use the Exit key to close the applications and I shall check on the picture size.
Yesterday, I encountered another problem. I have taken a picture with the phone camera and used it as the user defined wallpaper in a downloaded theme. After a few days, I decided to delete the theme and the picture. I managed to delete the theme but whenever I try to delete the picture, it was said the file is opened. How can I check. I tried using the FExplorer to delete but were unsuccessful. The strange thing is that I did not attach this picture into my current theme. I had used another picture instead; but after a while, the wallpaper just changed to the picture that I wanted to delete instead of the one that I have defined. Please advise, how I could close the wanted picture and delete it from my 7610. Thank you so much.
