Is there any software available for the nokia 6600 which can search and find offending files/softwares installed on your phone and delete them ???
Locating files
craio, i don't know if u ve seen a post of mine a couple of days ago.. I had a similar problem. I had transferred a .sis file to the phone and later I could not delete it. Smart enough as always;D I used Oxygen Phone Manager, to view the message from the PC. Oxygen has a great function which tells you where a message, an attachment etc... is located in the phone or mmc memmory. So I d guess this program can be the solution to your problem😉
Get FExplorer. Search the forum for a link to the software.
cmatthee wrote:Get FExplorer. Search the forum for a link to the software.
Or just look in the 'shop' above to save searching Lol 😊
Well, i do have fe explorer on my phone, but i wanted to know if there is a software that can locate....... a hidden corrupt file on the phone and delete it.......kinda like wht the anti virus does on the pc.....with so many softwares installed it kinda becomes hard to pin point what could be the offending file.....i know there is a file that is corrupt on my phone but i cannot locate it.....
craio wrote:Well, i do have fe explorer on my phone, but i wanted to know if there is a software that can locate....... a hidden corrupt file on the phone and delete it.......kinda like wht the anti virus does on the pc.....with so many softwares installed it kinda becomes hard to pin point what could be the offending file.....i know there is a file that is corrupt on my phone but i cannot locate it.....
What made you say its corrupt? Can you name the symptoms. Have you been installing cracked psiloc apps? 🙄
