I'm looking for software for my PC/Nokia 6600 that will allow me to read and send text messages via the phone from my PC.
My bluetoth connection is all set, and I use the Nokia PC suite.
I've tried using RemoteS60, and although it can be used to send text messages, I found it so cumbersome that its easier to use the phone.
The previous Nokia PC suite I used for my old Nokia 7200 had a nice facility for processing text messages, but this appears to be lacking in the new PC suite.
Cheers,
Bernie
Try "Desktop Message". It is available through the shop: http://www.allaboutsymbian.com/shop/
Thanks for the reply, but I can't find any refererences to Desktop Message anywhere, other than a couple of forum posts.
Any idea where I can get it?
Cheers,
Bernie
littledude wrote:10 mins later errm The shop
lol
Chris,
Which part of 'I can't find any refererences to Desktop Message' didn't you understand???
Bernie
let me know what the software is like if you get it
also littledude, where in reading u from? thats where i'm from too, and also called chris, lol
1: Go to shop: http://www.allaboutsymbian.com/shop/
2: In the "Software Shop" section on the left, pick, e.g., "Purchase software in EUR (Euro", or "Purchase software in USD ($)"
3: Pick the "Nokia Series 60"
4: Up in the "Search for software" keywords field type "desktop message" without the quotes for keywords (actually, you find it even quicker if you type "DesktopMessage" with the quotes).
5: Select "DesktopMessage for Nokia 7650/3650" from the list.
6: Select "Try It" for a trial version or "Buy It" if you want to buy it.
N/A wrote:Try "Desktop Message". It is available through the shop: http://www.allaboutsymbian.com/shop/
Desktop Message did not work on my 6600. Rather look at Oxygen Phone Manager for Symbian OS phones. It works very well with the 6600 via bluetooth and IR. It also provides alot of other features as well 😊
