How to remove application?
4 replies · 28,893 views · Started 02 September 2004
How do I remove unwanted applications from my Nokia 6600?
According to the manual, I sould be able to select the icon and choose 'remove', but there is no 'remove' option.
Cheers,
Bernie
Launch "Manager" app, select program you want to uninstall, hit "Options", select "Remove".
This, and many other useful things are explained in the User's Guide that you should've gotten with your phone. 😉
