image sizes used on 6620
3 replies · 1,995 views · Started 03 September 2004
just got the 6620. i move alot of files around from pc to cell and vice versa. So i'm trying to figure out the image sizes needed. When using the Nokia Image software it asks which one you are using..
wallpaper
mms
portrait
trying to figure out what the size of these images should be so i can avoid using this software and just move them over to my phone at the correct size. Is portrait the image size used for people when adding pics to contacts?
start filling in my own thread..
background = 176 x 208 pixels (this is the full size of the screen)
icons = 42 x 29 pixels
portrait images = 80x96 pixels
Here is a bit of info. The 6620 doesn't use the full screen to display wallpaper. It uses 143x176 [heightxwidth]. Any more in either direction and it scales your wallpaper loosing quality. So for best results use the exact height or less and the exact width or less.
-dave
djplayer wrote:just got the 6620. i move alot of files around from pc to cell and vice versa. So i'm trying to figure out the image sizes needed. When using the Nokia Image software it asks which one you are using..
wallpaper
mms
portrait
