mBrain Software releases the 2nd public beta of Pdfprinter
0 replies · 2,936 views · Started 01 October 2002
PdfPrinter allows you to create Adobe Acrobat files (also known as PDF files) on your Psion and compatible PDA, and on the Nokia 9200 Series Communicator.
PdfPrinter is a printer driver, which means that you can create PDF files using almost all programs that can print, such as the builtin Word processor, Spreadsheet, Fax editor and Agenda, and numerous third party programs.
PdfPrinter can create PDF files with version 1.2 (Acrobat 3.x ), 1.3 (Acrobat 4.x) and 1.4 (Acrobat 5.x).
PdfPrinter compresses the result to maximise your storage space and to minimise your transmission costs.
You can also encrypt the generated PDF files (using 40- and 128-bits encryption), set passwords, and set access rights.
PdfPrinter for Psion and compatibles is available at www.mBrainSoftware.com/Psion/PdfPrinter/PdfPrinter.htm.
Pdfprinter for the Nokia 9200 Series is available at
www.mBrainSoftware.com/Nokia/PdfPrinter/PdfPrinter.htm
