p900 restarting
7 replies · 1,916 views · Started 04 September 2004
i have a problem with my p900 witch restarts after each instalation OF ANY APP :frown:
is that normal???!
or i have to Format it!!!
I think that was a problem in old firmwares, try updating to the latest!
if you already did and still have the problem, then there might be a software that is causing this issue, do as Delta737 said formatting id your only choice
thanx guys for your help 😉
guide me guys through this process, i'm planing to do the following:
1. Formatting the phone and the memory card (after backing-up personal information)
2. Updating the firmware.
3. re-installing the Apps that i need and my personal information
dose that sounds good 🙄
No :tongue:
Once you update your firmware it automatically formats the phone, so that would be doing more work than necessary!
:tongue: thanx
but what about the memory card's Apps :con? (in my phone's case)
is it better to format the MC as well, or just leave it as it is? 🙄
many thanx
