PhotoRite SP - a Photo Camera, Editor, Viewer you can't miss!
9 replies · 8,304 views · Started 04 September 2004
Capture enhanced quality photos with creative photo frames and funny magic mirror effects! PhotoRite SP for Nokia Series 60 is a Photo Camera, Photo Editor, Photo Viewer all-in-one imaging application for you Nokia camera phone. Main features includes:
- Fully support on-phone camera with real-time preview of ALL effects and photo frames
- One-Click Autofix!
- Unlimited photo frames!
- Magic Mirror!
- Slim-up/Blow-up your body and face!
- Soft lens, black and white, sepia effect!
- 8x digital zoom
- Full screen browsing & viewing
- Thumbnail list browsing
- Photo Rotation, resizing
- Compatible with NOKIA Series 60, 7650, 3600/3650, 3620/3660, 6600/6620, 7610, 6260, 6630
Learn more, download FREE trial, buy now:
http://www.PhotoRite.net/photorite_sp/
does this program cover the preview screen while you are about to press 'capture' ?
This is one thing I don't like from my 3660.
I always miss the target because the popup menu covers the entire screen.
If this program just give me the option and no cover the screen...........it's mine then!
cya
CasperVD wrote:does this program cover the preview screen while you are about to press 'capture' ?
cya
I think you're doing it the wrong way, why the popup menu covers the screen, all you need to do is click the center of the joypad to capture, you do not need to use the "menu" options.
Yeah - just press the joypad in to take a pic without the menu getting in the way, works the same on the regular cam too mate 😊
Most common options can be 'fired' this way without the need to enter the menu system..
Almost perfect, if only it would remember your settings and always save to MMC.
AND also open in camera mode rather than file mode.
AND if I could put it on a soft key wheyhey!!
Autofix is a little harsh I found and make the dark areas look grainy, would work well on a 'decent' digital pic but the camera pix just can't take that kind of enhancement..
lsm0325 wrote:I think you're doing it the wrong way, why the popup menu covers the screen, all you need to do is click the center of the joypad to capture, you do not need to use the "menu" options.
Perfect!!!
Thank yoU!!!
cya
