it is the first time that i write a subject in this forum, hoping that i am giving what is good for all..
every body knows that nokia 7610 can accept AAC files as a music tone..
from now on every body will make that AAC files after this program and codecs with it:
the program called :
dBpowerAMP Music Converter (free download):
http://www.download.com/dBpowerAmp-Music-Converter/3000-2140-10042534.html?part=dldbpoweramp&subj=dl_music&tag=button
the program just convert from WAV to MP3 and vise versa..
with these codecs and decodes you can find that the programm will convert MP3 and WAV to AAC(advanced audio coding):
http://www.dbpoweramp.net/codecs/dBpowerAMP-codec-mp4-aac-decode.exe
http://www.dbpoweramp.net/codecs/dBpowerAMP-codec-mp4-aacenc-alter.exe
http://www.dbpoweramp.net/codecs/dMC-AAC-Codec.exe
after downloading and starting the program ...
Dont forget to convert from MP3 to AAc with this (preset bitrate 64kbit/s)
you will get the same quality as the mp3 with half size.............
i hope the best for every body... 😉
bobo305 wrote:it is the first time that i write a subject in this forum, hoping that i am giving what is good for all..every body knows that nokia 7610 can accept AAC files as a music tone..
i got some problems here using this program. Hope that u can help...
can i know how to rip one part out? Using the dbpoweramp(normal) or the powerpack? Its quite confusing and wat are the codecs that u gave us for? How do i use them actually? Actyally, my main purpose for using this program is to rip one part out and use them as truetone(either wav. mp3. or aac. format also can)Hope that u can teach me...sorry cos i m quite slow..heex...Thanks :con?
