Pinboard Editor?
1 replies · 1,457 views · Started 05 September 2004
Anyone know if there's a pinboard editor available? I want to get rid of some of the annoying network provider entries that can't be deleted via the UI.
Kieran wrote:Anyone know if there's a pinboard editor available? I want to get rid of some of the annoying network provider entries that can't be deleted via the UI.
There is a program called AppMan.
It�s a Taskmanager. you can use it to add anything you wat to the pinboard, but not to remove that stuff you said. To do so you need to get a original pinboard file than add the shortcuts you want.
