2 Probs with 3650
6 replies · 2,248 views · Started 05 September 2004
1. If anyone knows how to send a fax from the PC through 3650 using bluetooth I would apprieciate if he told me. I'm using a belkin bt dongle f8t003.
2. Can't delete a file from MMC. The file is E:\System\Fonts\Phoneticfont.gdr. I even tried formating the MMC but it won't do it. It says the format went OK but it the files are still there.
Thanx in advance
urke wrote:1. If anyone knows how to send a fax from the PC through 3650 using bluetooth I would apprieciate if he told me. I'm using a belkin bt dongle f8t003.
Thanx in advance
Format the phone then the mmc. or do a safe mode then try formatting the MMC. Probably, a phone app is dependent on that file so it didnt went well with the format mmc. Its just probably some sharing conflict.
Kamalayan wrote:Format the phone then the mmc. or do a safe mode then try formatting the MMC. Probably, a phone app is dependent on that file so it didnt went well with the format mmc. Its just probably some sharing conflict.
I tried the safe mode format but that didn't help.
How about sending faxes, has anyone ever done it before?
urke wrote:2. Can't delete a file from MMC. The file is E:\System\Fonts\Phoneticfont.gdr. I even tried formating the MMC but it won't do it. It says the format went OK but it the files are still there.
As someone else suggested, you need a card reader because the file is locked by the phone while it's switched on and therefore it can't be deleted.
Even better, move the file to a temporary location in the card, and put it back into the phone. Now the file should not be locked anymore, move it to C:\System\Fonts\ so that if some application is using it, it will still find it.
Thanx in advance
Send a fax from PC tru 3650 ? u mite as well send it tru a pc .. if u have xp .. u have a built in fax software. i guess u can send only emails tru the phone. :redface:
dhanesh wrote:Send a fax from PC tru 3650 ? u mite as well send it tru a pc .. if u have xp .. u have a built in fax software. i guess u can send only emails tru the phone. :redface:
A bit of a misunderstanding. I do not have a landline so I need to use the cellphone to send/recieve faxes. I tried all sorts of things, searched the net for answers but nothing works. :frown:
BTW, I solved the card problem. Moved the file as suggested and restarted the phone. Works as a charm. Thanks mimmo :icon14:
