Dear All
I have installed GoBoy and successfully transfer rom to inbox. I can start GoBoy and see the game menu. But neither "select" nor "start" works. Nothing happen when I press them. What am I missing????
Thx for help
Dear All
Thx for help
save the file from inbox to the designated directory where the roms should be (this is a guess, if GoBoy should be able to see files from the inbox directly, then the rom filetype could be wrong)
Dazler wrote:save the file from inbox to the designated directory where the roms should be (this is a guess, if GoBoy should be able to see files from the inbox directly, then the rom filetype could be wrong)
According to Goboy doc. It should have a \Goboy directory in my N-Gage. But I cannot find one using PC suite. It also don't allow me to create directory under the device. How to do so then????
Install a program called fExplorer (use google) and you'll be able to create directories and move files etc... (with/on your phone)
