New: MeetingPoint for Series 60
1 replies · 1,481 views · Started 06 September 2004
MeetingPoint is a free piece of software which allows you to 'locate' other users using Bluetooth. The idea is that the software will search a certain channel for your contact at a meeting point so you can meet up. The software also allows you to send messages to everyone within range regardless of whether they have meeting point or not (which could get annoying for others).
Author's Description
...the bluetooth contacting application
MeetingPoint is a free, simple, short-range contacting software, using Bluetooth wireless technology.
Bluetooth can "see" through walls, doors and people, at all directions at the same time. Its effective range is usually 30ft (10m).
MeetingPoint follows the CB-style paradigm of channels, where people on the same channel are able to send messages to each other.
It works on supported Smartphones, PDA (Personal Digital Assistants), and also on Windows PC/laptops.
It''s useful for:
* Arranging a meeting with someone you don''t know in person (e.g. virtual friends from a chat room). Just tune your MeetingPoint to a previously agreed channel, and go to the meeting point (airport, crowded pub, etc). When you are within range, both MeetingPoints will fire audible alarms, making you aware of the other party's location.
* Contacting like-minded people, or pals sharing your interests, religion or preferences. For example, if you are a huge fan of the Red Hot Chili Peppers, you might want to search for others using "REDHOT" as your channel.
* Mass-sending a message to everybody within range, not just MeetingPoint users.
