Smart Dialer aims to speed up the retrieval and dialing of your contacts in your phone. It implements an auto-complete like fuction. As you begin to dial the software pops up and offers suggestions for what number you might be trying to dial. It works vy looking at either the number you are dialing, or the first or last name (all at the same time). Well worth a look.
Author's Description:
Despite everything you can do with your smartphone, the main reason you have the phone is to call people. Symbian phones are great, but why does it take so long to dial someone you've called 100 times before? Smart Dialer makes it easy to call anyone in your address book within 2-3 clicks.
Smart Dialer is compatible with the Series 60 smartphone platform including the Nokia 3650, 3600, 3620, 6600, 6620, 7650, 7610, N-Gage, N-Gage QD, Sendo X, Siemens SX1, and other Series 60 Devices.
Usage
Smart Dialer is easy to use:
* Just start dialing as you normally would
* Smart Dialer pops up automatically, giving you a list of possible numbers to dial. Select the number you wish to dial
* Hit the dial button (or the OK button)
Features
* Completely automatic - dial numbers as you normally would
* Dial by first name, last name, or number - all at once!
* When dialing by name, there's no need to tap a given key multiple times for a single letter (to dial "C", just hit the 2 button once, not three times)
* When dialing numbers, you can dial starting from the beginning or starting after the dialing prefix if you set your "favorite prefix"
* Speed dialing, sending key tones, DTMF sounds, and all other features of the original dialer are preserved
* Automatically syncs with the address book information on your phone
* Option to "Resync with Contacts" automatically appears when Smart Dialer detects that one or more of your contacts has been changed or added
* Option to temporarily disable Smart Dialer until next completed call
* Smart Dialer runs in the background at all times and automatically starts when you start your phone
* Trial version is fully functional with no nag screens
