GPRS disappear
5 replies · 2,094 views · Started 07 September 2004
Hi!
My P800 often lose GPRS!
When I tap the network indicator the folowing message appear:
Network:YU Mobtel
GPRS:Unattached
(GPRS not allowed)
In the closed flip mode the Status says:
Battery level...
GPRS: Availeble
GPRS not allowed
Date....
That last a couple days,and GPRS return in normal!
When I insert another SIM card from same operator,GPRS still mising!But,when I insert SIM from difrend operator GPRS work(but not always,sometimes I have same problem with this SIM)!?
Is somebody have same problem?
What is this? 😡 :con?
Thanks in advance!
This is definately a problem with your service provider (YU Mobtel). You should contact them and ask for an answer!
tapuskof1 wrote:Hi!
Network:YU Mobtel
GPRS:Unattached
(GPRS not allowed)
Battery level...
GPRS: Availeble
GPRS not allowed
Date....
Thanks in advance!
It happens also on my phone sometimes and I think the guys right, we cant blame it on anyother but the provider since its their server thats giving the phone the gprs signal (or something like that). Justified if you have not touched any other configuration on your phone at that time.
I contact my operator,and I ask them for this problem,THEY DON'T KNOW!!!
We tray everything(reset the GPRS on server,phone master reset,and...),but nothing!
After couple days he come back,like nothing heppened!
That drive my nuts!!! 😡 😡 😡
I can't receive my mail(I can,but CSD is very expensive)browse wap&web...AAAAA
Thanks guys,I think that happened only to my phone,and only MY PRECIOUS P800 is spoiled,corrupted,damaged...Because I always has the bed luck with mobiles!
tapuskof1 wrote:I contact my operator,and I ask them for this problem,THEY DON'T KNOW!!!
Well if it happens again, try comparing it with a person who has the same provider to see if his GPRS is active or like yours which is not. That'll probably give you a definite answer on who's to blame, the phone or the provider. 😃
Interestingly I have a similiar situation that cropped up about 2 months ago, here are my symptoms:
1. the blue indicator (above signal strength) showing a GPRS connection disappeared (although I had been for well over a year with GPRS always connected/attached)
2. if I turn the phone off and back on, the GPRS is connected and then disappears soon afterwards
3. if I try web browsing, it initialises and connects correctly and the blue indicator comes back on!
I really have no idea if this is due to the operator (Telef�nica M�viles here in Spain) or that my P800 has suffered one too many bumps! In any case, it doesn't appear to be causing me that much grief.
Regards,
Lonnie
