ringtones in MMC?
2 replies · 1,863 views · Started 07 September 2004
Hi all.
How can I use a wav file stored in my MMC as a ringtone?. Is it possible?.
thx.
Richie wrote:Hi all.
thx.
People should really try using the search function on the forum...
thx.
Hard one. 😉 Hmmm... let me see... put the file in E:\sounds \digital. (Using a card reader or any file manager utility) if its sent via BT then its saved directly to the x:\sounds\digital folder where x is the default memory in use. Go to the profile you want to modify and assign the wav file from there. Im a 3660 owner, i just hope its the same with engage since its both symbian...
