Does anyone know if you can change the midi sounds that are used on the phone? I have many high quality midi sounds that I would like instead of the mediocre ones used on cell phones.
can you change the midi tones?
??? wrote:Does anyone know if you can change the midi sounds that are used on the phone? I have many high quality midi sounds that I would like instead of the mediocre ones used on cell phones.
Yes you search the forum first before you ask. Anyway, you put them in the x:\sounds\digital folder where x is either your c: or e: drive. You need a file manager to do this or a card reader.
