Nokia 6620 Operator Logo
1 replies · 2,042 views · Started 08 September 2004
I bought an ATT branded nokia 6620 on ebay. I want to get rid all of the ATT files on it and also I tried changing the operator logo using Fexplorer but it doesnt work. ANy ideas why is this? ANy suggestions? Thanks guys.
kathy2425 wrote:I bought an ATT branded nokia 6620 on ebay. I want to get rid all of the ATT files on it and also I tried changing the operator logo using Fexplorer but it doesnt work. ANy ideas why is this? ANy suggestions? Thanks guys.
Post from domi: http://www.allaboutsymbian.com/forum//forum/thread/13991/&highlight=operator+logo+att
Don't care about the size of the image, any jpg or gif are re-sized to fit the correct size (only the bmp are kept)
Only the jpg, gif and bmp files can be used !!!
1) take a picture
2) go to c:\nokia\images select this picture
3) go to file > set as operator logo
4) wait a while until reboot ....
if the logo doesn't display :
1) go to c:\system\apps\phone\oplogo
2) ckeck there is a file in this directory, this file must be in the format of :
ABC_D_E.bmp where ABC (mcc) and D (mnc) are the codes of the operator (you can check them thru FExplorer with Network/info), E is generally 0
if you haven't, you can always copy a bmp file (with the correct filename) into this directory and reboot to perform a test.
ATT: I have noticed that some operators don't allow to change the logo.
Hope this help,
Domi.
