need help with 3660
4 replies · 1,419 views · Started 08 September 2004
hi i juz bot 3660 so dunno much abt it..ytd i tried putting applications to my memory card via my frens card reader.everything went well til i put the mmc back to my fone.nothing appears but when i check the status of my memory card..the free capacity is lesser now..
has this gotta do with me not having a filemanager or some sort?pls help thanx!
flare wrote:hi i juz bot 3660 so dunno much abt it..ytd i tried putting applications to my memory card via my frens card reader.everything went well til i put the mmc back to my fone.nothing appears but when i check the status of my memory card..the free capacity is lesser now..
So u didnt install the SIS files, you just copy the folders of the applications? If thats the case then that wont work because some applications require some files to be extracted on the phones memory. It would help if you identify what applications you copied.
If those were installation files (SIS files) then you need a file manager like fexplore to navigate your way to the sis file then install it from there.
do I need to upload fexplore via infrared/bluetooth? have no way to do it, so the only way it's MMC.
If I can open fexplore from MMC then it's easy
Cya
