hey everyone.. just a quick question..
i can't download data from pc to phone using pc suite?
could i?
thanks very much.
could i?
thanks very much.
If you talking about nokia PC suite ... yes you can .... but it only support Pics .. contact and son on ... just everything in the menu ... but not midi,wav mp4 and so on ... that one you have to used infrared menu under windows to transfer these files to your Phone from PC ... 😃
thanks very much for your reply!!
okay.. got it now
😃 cheers
yeah.. thanks again..
but what i meant to ask also was that i can't upload from my phone to the pc (files other than images?
[quote="asoffian"] ... that one you have to used infrared menu under windows to transfer these files to your Phone from PC ... 😃[/quote]
Asoffian, Can you go into a little bit more detail on this, In XP I have a util that uploads files but in 98 I cannot find a way to send files from the PC to the phone
erm.. yeah, i'm using XP as well, and wireless link will just enable you to send files from you PC to your Phone.
however, i'm not sure if you can send stuff from your phone.. wonder if seleQ will do that for you?
