can i disable keylock somehow...i hate when it starts...how do i shut it off on the p800?
turn off keylock
noob13 wrote:can i disable keylock somehow...i hate when it starts...how do i shut it off on the p800?
click on the battery icon, then settings, and diable the "screen saver device lock" option, and... rtfm! 😉
well its not tath lock i ment...i mean the lock tath starts when you close the flip...
you know...
press ok and * to unlock....
my touch screen dosent work,but the screen looks great besides that,,,so i dont need that lock...its just there to anoy me..i only use the jog button.....
yeah..its anoying,,,bet hell a new screen is expensive...so i have to live whit this....until i find a cheaper used display...
noob13 wrote:well its not tath lock i ment...i mean the lock tath starts when you close the flip...
you know...press ok and * to unlock....
my touch screen dosent work,but the screen looks great besides that,,,so i dont need that lock...its just there to anoy me..i only use the jog button.....yeah..its anoying,,,bet hell a new screen is expensive...so i have to live whit this....until i find a cheaper used display...
@noob13
my suggestion pre-supposes that your touch screen works. If so, try this, in sequence: Go to Control Panel. At the bottom of the screen, click on "General" the click on "Phone Preferences". Under Preferences, click on "Locks". In the Locks menu, the keylock settings are found, including disabling the automatic key lock or re-enabling it if you wish to do so.
There is also another way, which will also bring you to the Locks menu: Go to "Phone", then click "Edit", "Preferences", "Locks".
Hope this helps.
