I had PC Suite 6.1 installed on my system, but had no luck browsing with the usb cable, reading here I downloaded 6.3 & tried to install, but I keep getting the error, Nokia Multimedia Player is installed, this needs to be uninstalled first & then the installation ends.
I can't remove Multimedia Player via Add/Remove, it just stops half way through.
I've done a search for all files containing nokia multimedia & deleted them but still no luck.
Anyone know of a hidden file or a way to get this older version deleted.
(XP)
