QD folder icon
13 replies · 4,484 views · Started 09 September 2004
any one know how to change folder icon? or where is the aif file saved? Thanks
xgigi wrote:any one know how to change folder icon? or where is the aif file saved? Thanks
there is an application called smart launcher, that use skins to change the folder icons. but i really don't recommend smart launcher because it fills the phone memory and kills you slooooowly... :icon13: :icon13: :icon13:
drager wrote:there is an application called smart launcher, that use skins to change the folder icons. but i really don't recommend smart launcher because it fills the phone memory and kills you slooooowly... :icon13: :icon13: :icon13:
thanks drager, I do know SmartLauncher. As you said, it consumes many system resource, furthermore it does not surpport Chinese, btw I am from China. So I mean, is there any way to customize manually? Or do you know how SmartLauncher works?
Any one know this, please tell me, thanks!
xgigi wrote:thanks drager, I do know SmartLauncher. As you said, it consumes many system resource, furthermore it does not surpport Chinese, btw I am from China. So I mean, is there any way to customize manually? Or do you know how SmartLauncher works?
I think it just skins the icons something like how a projector works... 😃 Anyway take a look at this http://www.ngamers.de/html/modules.php?name=News&file=article&sid=348 it does not change the folder icon but it does change the default system icons. If this has been done then maybe the develope of the program can also change the folder icons. Will be really cool. 😃
Chill!!!
Kamalayan wrote:I think it just skins the icons something like how a projector works... 😃 Anyway take a look at this http://www.ngamers.de/html/modules.php?name=News&file=article&sid=348 it does not change the folder icon but it does change the default system icons. If this has been done then maybe the develope of the program can also change the folder icons. Will be really cool. 😃
Chill!!!
I have installed that icon package, it seems to create a shortcut in MMC with same UID as the app on disk Z, then define a new icon for the shortcut. But where is the original folder icon defined, I can not find out.
Dazler wrote:What do you guys means with Folder icon???
I don't get it :$
Like the Connect folder Extras folder Games folder....
The folder icon of ngage can be changed, but requires scripting. it is integarted with the Palet. But some guys at the site that Kamalayan suggested have claimed that they have nearly mastered the scripting. And soon it will be possible.
kishtya wrote:The folder icon of ngage can be changed, but requires scripting. it is integarted with the Palet. But some guys at the site that Kamalayan suggested have claimed that they have nearly mastered the scripting. And soon it will be possible.
Thanks guys, could you advise something ahout the script?
Yey!!! 😃
Any news from that script ?
MikePT wrote:Any news from that script ?
I too is on the guard and has been waiting for a long time for that folder changer... :frown: I kept visiting that page but still no avail.
i got questions here..
i used sysiconz
how to make aif file?
on my QD, sysiconz doesnt change recorder, apps, vidplayer, & serv nos icons. :frown:
how to change them?
is that using script? or i just need create freakvoicerecoder folder etc?
last,
can i change folder icon?
thx
