Hi guys!
Does anybody know how to replace the icons set of a theme with another icon set from another theme in 7610?
I have FExplorer but I can't see any files related to the icons of a theme. Do I need other software to transfer the icons from one theme to another theme?
Ray
Raymond Ee wrote:Hi guys!Does anybody know how to replace the icons set of a theme with another icon set from another theme in 7610?
Ray
Just go into the themes menu and click 'edit' on the theme you are using and change the icons in use,you will get a choice from all the other themes currently installed.
elton wrote:Just go into the themes menu and click 'edit' on the theme you are using and change the icons in use,you will get a choice from all the other themes currently installed.
I have gotten my 7610 about q week back and it does not have the fuction as described above. Could it be that this feature is removed in 7610? Any 7610 owner has the same experience as me?
Raymond
hey guys...mine doesn't have the option to change the icons too
Sorry,
I have checked my mates 7610 and its not there either,i just posted the above advise thinking there is no way they would remove this!!!!!!!!!!!!!!!!
I was thinking of getting a 7610 but there just seems to be too much missing.
So ther is no way to to change the icons of the themes installed in Nokia7610.
Vicky wrote:So ther is no way to to change the icons of the themes installed in Nokia7610.
There is a way... look here a thread I post
http://www.allaboutsymbian.com/forum//forum/thread/34321/
Bye Pedro
