A question about 3650 !
8 replies · 2,120 views · Started 09 September 2004
Is it possible to execute a .sis file from the MMC ?
Or how can i copy a file from MMC-Card to the Phone Dicectory "C:\Nokia\installs" ?? :con? :con?
I copied the fexplorer.sis file on my mmc card by card reader and it did'nt appear on Manager : (
Please Help me
Thx
Fischmann 😉
Have the same question like you Fischman...
I wonder if I just can copy/paste .sis files to my MMC.
It worked fine with images, .wav and .mp3 but not the same with programs.
Hope that somebody will help us.
CasperVD wrote:Have the same question like you Fischman...
It is so easy, install seleQ on the phone and then execute the copied .sis file from the mmc😉
Perfect, I download it but have a trouble...
...still haven't bluetooth/infrared connection, so I am disconnected 😞
Is it a way to install it from MMC?
Thankx kentsumi,
cya
im sry , but there is no way to install a sis file from the mmc .......
Fischmann wrote:Is it possible to execute a .sis file from the MMC ?
Please Help me
Thx
Fischmann 😉
It is not only possible to put the .sis file on to your mmc it is also dead easy.
Download and unzip to PC;
Use a card reader to transfer the unzipped .sis file to the mmc;
Using FExplorer (or Seleq) go to E: drive and it ought to be in there;
Click on the .sis file that you want to install and the phone then guides you thru the rest of the proceedure (it first saves the file to the installer! Smart eh!).
I do it this way all the time as the bluetooth connection between Nokia PC Suite and my 3650 DONT work (grrrrrrrrr) and is also much slower than a card reader. Hope this was of some help
Hi'
At least Your phone should have a program like Fexplore or selq(Any file manger). With the help of IR connectivity or Bluetooth kit you can easly install FExplore. without any file manger its very difficult to locate the sis file from MMC. Actually you no need to copy the sis file to c:\nokia\install. because sis file is a executable file and when you open sis file,it will automaticaly create an entry in the c:\nokia\installs.When you are unistall the program through the App. manger the entry will delete automaticaly.
regards,
Baiju.
