Help!! Can't copy contacts to sim card
1 replies · 23,846 views · Started 09 September 2004
i need help copying my contact's #s to my sim card. i know the user guide says to go to the # then select copy to sim direct. but, it ain't working. i'm getting the "not copied" error msg. is there something that i need to do in order to access the sim card to copy the info over? your reply is greatly appreciated. thanx. :con?
Make sure there are no spaces () or - in the phone number as does happen when synching with Outlook sometimes. Then you should be able to copy to the sim.
Brie
tommy024 wrote:i need help copying my contact's #s to my sim card. i know the user guide says to go to the # then select copy to sim direct. but, it ain't working. i'm getting the "not copied" error msg. is there something that i need to do in order to access the sim card to copy the info over? your reply is greatly appreciated. thanx. :con?
