Hi I'm new to this - so be gentle!
I'm a relatively new 7650 user and just yesterday out of nowhere the volume on my 7650 got real low.
All the profiles are set correctly with the volume maxed but ringtones, recorded sound clips and downloaded midi's seem to play at a really low volume? :-?
The only changes I have made to my unit since purchase have been to install a trial version of the seleQ file manager and sTools apps.
Anyone have any Ideas?
Check whether handsfree button has been activeted or not .... ( red button with Pacman face ) .... try push it on and off and see the different 😃
Mmm... yeah its not that. Even ringing tones are not as lound as before.
Someone has suggested that the mesh covering over the speaker hole on the top of the phone may have cave din to block out the speaker - looking at it they might be right!
Help! can I fix it easily?
Try checking the ringtone volume using Profiles->General->Options->Personalise->Ringing Volume. Crank it then activate the profile (Profiles->General->Options->Activate). If this doesn't help then it looks like something like the speaker... :cry:
the volume depends of the quality of the midi file
say are you trying to say the volume depends on the quality of the midi file?? 😃
weird 4 posts from 7650 yet it states only 3 on his posts ! ?
Got it Fixed!!! 😃
Took it to my local service centre. They said there seemed to be a qty. of metal filings??? )Its only 3 weeks old!!) round the loudspeaker that was causing a reduction in volume.
He cleaned it and its now ok whoopeee!
HOw can i put MIDI files on my 7650 ? i havnt got blue tooth connector for my pc, can i send then of my pc via email to my 7650? any help apreciated .
Yes you can send midis as email and download them as atachements 😊
[quote="7650"]the volume depends of the quality of the midi file[/quote]
I've heard of trying to increase your post count, but 4 repeat posts in the same thread is just taking the pi$$ a little. 😃
IZZO 😃
Hmm.. too bad when you delete a post your number goes down.
I was thinking of posting a 100 repeated posts in a haunted forum while everybody is sleeping, then deleting them and i get to keep the number 😃
[quote="😊"]Hmm.. too bad when you delete a post your number goes down.
I was thinking of posting a 100 repeated posts in a haunted forum while everybody is sleeping, then deleting them and i get to keep the number 😃[/quote]
hahah maybe we can post one sentence then post then another sentece post again
