How can I suppress the stupid sounds
3 replies · 2,273 views · Started 09 September 2004
The Sendo X always sounds by switching On/Off, Connecting with the cable, making an agenda entry...but I was setting the "warnings sound" off.
That nerves. For example: When I go the bed and the wife and/or the kids are sleeping and I shut my phone off all family members will be awake! :tongue:
Or in the cinema/theatre when all goes silent and then I switch of the phone with that loud sound. :redface:
This is not necessary :frown:
Any ideas?
I totally agree!! Stupid not to be able to turn off those ridicilously high sounds!!
Only thing to remedy it is to insert the headset plug! :frown:
Also the sound level of the keypad (if turned on) is insanely high!!!!
Do Sendo think that we are 90 year old deaf people???
Even when it's on level 1 it's just as high as on a Nokia 6600
with max volume!!
for some people it's never ok
the phone is too quiet, the phone is too loud etc etc.
p.s. when i insert data cable i don't have a sound
when i start up the phone you have the sound, i hate it that i can't turn it off, but i think the new firmware will have this option.
Yes, only with the charging cable a sound appears - you are right and
yes, I also hope that this will solved with a soon Firmware-Update (and lot of other problems) 🙄
