Realplayer Continuous Play???
2 replies · 3,046 views · Started 09 September 2004
I've transferred some MP3s to my 7610 Memory card with a playlist.
When I try to play the playlist it will play one tune, then stop. I'll select the next tune, which it'll play, then stop again. For some unknown reason it seems to be on 'single' play, instead of 'continuous'.
Whether I create the playlist on the PC or on the phone makes no apparent difference. I downloaded UltraMP3 which played tunes continuously with no problems. I don't particularly fancy paying for this privelege though.
Any ideas?
Cheers guys.
GTSkater wrote:I've transferred some MP3s to my 7610 Memory card with a playlist.
Any ideas?
Cheers guys.
You dont have to buy ultra mp3!! i got it from a nokia 6600 site and it works perfectly for me!! if u PM me for it then ill giv it to u!! 😊
Open RealOne Player. Go to Options, Settings, Audio ... and change "Repeat" and "Random Play" to both On (if you want)
Now go Back, Back
Options, New Track List. Select a place to save the playlist. Then add a song. Then continously add a new song by Options -> Edit Tracklist -> Options -> Add sound clip
Hope that helps! I find RealOne Player better than UltraMP3, if you wanted my opinion ...
