i just bought a new n-gage qd and it is great.. but i just want to know how do i change the operator logo to a colour picture.. it is in between the battery life bars and reception bars.. ur help will be mostly appreciated..
logo
Make a 95x25 pixel image. Install FExplorer (http://www.gosymbian.com/) and use it to select the image on your phone, and from the FExplorer menu choose the option that does all the work needed to put that image as an operator logo.
To remove operator logo, go to c:\system\apps\phone\oplogo with FExplorer and delete files you see there.
This, and other useful answers you could also have located by using the search feature on these forums: http://www.allaboutsymbian.com/forum/search.php?
