Ive been using this 128MB MMC from Kingston.It worked fine untill i formatted the memory card while connecting the phone to the pc using windows disk formatter when i disconnected it,I opened the memory icon in the phone and it says "memory corrupted".Well, i format it again using the phone and it worked well. But when i connected the phone to the pc again, it wont detect the MMC.When i swaped the MMC with another one it worked well.Can any of you guys help me??
Memory Problem
The algorithm through which your phone and pc access the memory card are totally diiferent. That is why your phone can detect the card and pc can't. Try to open your memory card on some other operating system which has a different algorithm( Win 98 and Win xp have different algorithms). and complete a "complete format" (not quick) on PC, as the problem lies with you interupting the format process.
If it is not working try using some force methods by downloading software Badcopy pro. it can access corupt medias which includes mmc.
